SOLVED Safari/Javascript problem
I have just encountered a problem with safari/javascript on one of my webpages. I have a header that reacts to the mouse pointer but on both my MBP and iMac the header does not show in safari, it shows and works correctly in chrome and works properly on my wife's iMac in safari.
I used the javascript console to track down the problem and I have attached a screenshot of the output.
I can only assume there is a problem at my end as it seems to work on other machines and platforms.
I do not recall changing any settings in safari, but I am beginning to think that is where the problem lies.
Any thoughts or suggestions would be great.
Sorted! As soon as I posted this I noticed that it was trying to access the site using HTTPS://. I changed it to HTTP:// and it is all ok.
Cheers Cory, I was going to delete the post, but then thought it might be useful to someone else in the future.
