I don't know if Thunderbird permanently deletes EMails that you delete.
Suppose you are using V10.2 of a piece of software, and that was via an update to V10.2. If the developer comes out with V10.3, and you install it, and it works, you can get rid of the V10.2 update file.
Yes, some software can update itself, but in most instances, one can download the update itself, apply it, and get rid of the prior one. For VLC Player, I have always downloaded the update and applied it myself.
By permanent delete you mean all the emails that are seemingly deleted are somewhere in system memory?
Update file... I'm sorry, I must sound like a total retard, but you are not talking about those dmg files that are like windows .exe installer files? Because those go straight to trash after I'm done with them.
Although I get the feeling you do not mean those and therefore I need to ask - where exactly should I look for to delete old one? I don't want ot og rummaging in folders I should not touch.
So you download new VLC player file, delete the old from App Folder, then install new one?
With you internal drive taking up only a bit over 50 Gig (how do you manage to keep it that small?), the 200 gig you have free on your external drive is more than enough for a backup. But, from what you are saying, that drive is rather old. While the drive should be OK, due to light use, I would be skeptical. That is where you need a product liek TechTool pro to check out that drive.
Yes, SSDs last longer, are much, much faster, and don't take up much desk space (assuming you put one inside an external enclosure).
It might be bit more, but I can't check right now as I'm not at home with my Mac. But it is new, I have relatively few third party apps (I think entire list I have added myself is Malwarebytes, GIMP, VLC Player, Firefox, Opera, LibreOffice and maybe something more I can't remember) and almost no personal files. I'm in the process of moving maybe 300 GB to Mac from external drive. I used to do some hobby photography and need to sort through of all those photos, but I've been pushing it to future.
I have never needed to use anything else besides Malwarebytes.
Thank you! Some say you need nothing, some posters say you must put in Sophos Home or else you'll loose everything. With Windows background it is a bit hard to change my own mindset and the fears.
Yes, most definitely! Not sure about security, though, unless such updates contained security fixes.
Thank you, that is very important for me to hear!
I have never liked Safari, because it is just too slow. Up until about 7 months ago, I was using Firefox, which was fine. But Google Chrome is definitely a speed demon, and I like it. Opera is good also, faster than Firefox, but not as fast as Google Chrome.
I actually don't know what you mean by "Firefox and Opera quarantine supporting apps like Safari or not?".
Personally I am Firefox man and Safari's layout just does not do it for me. It feels clumsy. I use Opera for some emails, but Firefox for most surfing. I just love the NoScript I can add there as well.
I tried Chrome two times, but ended up uninstalling it due to the layout just not doing it for me. It feels too alien for some reason.
Well, I heard that if you download files with Safari, Mac adds this quarantine flag that warns if it suspicious file. But I don't know Firefox or Opera do the same.
https://support.apple.com/en-us/HT201940
- Quarantine-aware applications include Safari, Messages, iChat and Mail.
- These attributes include date, time, and a record of where the file was downloaded from.
