Hey all,
I'm back. Today my computer had another fit. After several weeks of no issues at all, it went to sleep randomly last night once - but woke right back up. This morning around 7am it went to sleep again. And again. And again. Several restarts, kext extensions deletions, "reset-nvram", etc. etc., it seems to have calmed down. The temperature was around 112F on the processor bottomside - nothing remarkable.
I'm completely convinced that it's a strange software issue at this point. When I boot it holding command+option+o+f, it *never* tries to go to sleep. I tested this in the middle of the fit it had. While in that mode it will not sleep (for at least 35 minutes of testing) while i play with the trackpad, type in random things, shake the laptop itself, change the sound and light settings, etc. As soon as I boot from there to the login screen... narcolepsy. Within seconds of seeing OSX, it'll start going to sleep about every 5-6 seconds, taking about as long to wake up again (I tap the spacebar continuously till it wakes up again).
Does anyone know what might be the issue?
FYI, I made a makeshift cooling stand like I saw in those websites. It's just plywood with four 1.5 inch struts that fit to the corners of the bottomside. The temp has been regular and reasonable since I've used the new stand. Good idea. It brings up this new issue, though - what if temperature isn't the only issue here?
Oh, one more thing, I was playing Diablo II when the sleeping fit started...
