Hi! I'm experiencing a kernel panic issue with my Mac Mini after it enters sleep mode. It restarts as expected, but upon logging in, I'm greeted with a "Your Mac restarted because of a problem" notification. I analyzed the kernel panic log using ChatGPT, which indicated the issue might be related to a DisplayPort timeout. My setup involves connecting the Mac Mini to a monitor through HDMI, while my PC, which is typically in sleep mode when I'm on the Mac Mini, is connected to the same monitor via DisplayPort.
Any suggestions are welcomed!
