There was no firewire socket on this camcorder unfortunately.
I've taken it back to the shop and got a refund. Will spend a few hours researching before I get another. Will make do with my current one which is compatible for the time being.
I think it's disgusting that they can charge such an amount of money for a piece of equipment but exclude Mac users. Well, they will include them if they pay either £54 for the software mentioned before or a total of £40 to upgrade to QT Pro and the Codec to make Mpeg-2 work.
Great camera but Sony need to get their **** into gear and not penalise us Mac users![]()
Hi Kyomii and iGirl - thanks for these posts, they've been very useful (unlike Sony).
However, Kyomii, I think what you've said about this camera having a firewire connection isn't right.
I brought a DCR-SR32E and it definetly has no firewire connection on either the camera or the docking station - so at the moment I seem to have a mac and a video camera that won't (conveniently at least) talk with each other. Have to agree with iGirl's disgusted attitude with Sony. For the money I spent firewire / mac connectivity should be assumed.
Does anyone know of an alternate docking station I could buy which is comptatable with the DCR-SR32E and which does have a firewire connection? (assuming the DCR-SR32E is indeed firewire compatable!?)
cheers for your help! Andrew
You do NOT need firewire to make this work on your Mac - just set up the USB on the actual camera when you plug it in as per my previous post here:
https://www.mac-help.com/forums/showpost.php?p=11615&postcount=10
It is listed in the instructions also, and you would have to do this regardless of computer/OS used.
It is a misconception that you require Firewire connection for such devices - Firewire is ONLY a method of transfering the data from one device to another, just like USB is.
Ensure the camera is not in easy mode, otherwise it will not work.
The ONLY thing that is not compatible is the software - and the alternative I have posted works fine.![]()
Yes, as I thought there is definatey a USB setting on it - there has to be, and my model is the same one apart from it is a slightly earlier version with a 30GB hard drive.
FIRSTLY TURN ON YOUR CAMERA AND EXIT EASY MODE IF IT IS IN EASY MODE - You can do this by pressing the easy button.
You need to plug in the camera to your computer. Then turn it on, then put into PLAY mode, then wait a few second and press P-menu (in bottom right corner)
Now, press "set up", scroll down or up to "HDD set" then click OK (on the bottom right)
Another menu will appear - scroll up or down to USB select, and press HDD - and then launch your program.
Compatibility is not generally an issue with camcorders, because the windows software is usually a driver (which Macs do not need) and an editing program, which you already have on your Mac.
