thanks!! i am attaching 2 more screen shots of what it does when i try to install other things maybe you know which program i need to choose ??
ummm lol the white one. idk. oh god i am a ditz![]()
i dont have the disc. i think i will will just go buy panther or just use my sons computerO.K. Version Tracker Pro is compatible with Panther so it should have opened. Try this, click once on the Version Tracker Pro dmg and hit the command and I keys. When the info window pops up, make sure that DiskImageMounter.app appears in the box that's under "Open with". See attachment. This is sounding like it may be system related. The apps that open dmg's, Installers, and zips are located in your System Library. If they are not there, you can't open these. Did your friend give you a Panther Installation Disc by any chance? Have you tried repairing permissions? I've placed Version Tracker Pro in a zip for you (See Link), do zips open for you?
http://snipr.com/2y25p-av3uc1
thank you for helping me!![]()
oh are you trying to make me lose whats left of my mind?
Open Disk Utility, located at /Applications/Utilities/Disk Utility
Select your startup disk on the left of the Disk Utility window
Select "First Aid" from the tabs if not already selected
Click the "Repair Disk Permissions" button
when i open the Utilities folder i only have 2 things in there airport setup assistant and airport utility
