SOLVED I installed a USB audio I/O driver and now it wont boot
I apologize aboout the - Data, that is for newer OSes. cd to Hard Drive/Library/Extentions, and you should see the files.
🙌 Hallelujah!
I finally found the file/package and removed it.
Why are there so many duplicate extensions folders? And without this file?
Anyway thanks for all the help.
I had to also use the -rf switch on the rm command whatever that is.
Sorry for leaving this problem and thread for so long. Life carries you away when late on the bills. I was prob subconsciously avoiding it too.
