Copy and paste to remote drive
I have downloaded some PDFs sent to me and wanted to store them on a remote hard drive. I have copied them Command C and them pasted them command v to the remote drive. A small window appears with a progress bar and oscillates stating it is preparing to copy and then says copying items to file folder I have selected. However, it just sits there with a progress bar (Grey) oscillating back and forth and never finishes or transfers the items.
Thanks for your response.
I tried copying to another remote drive and got the same results.
I then copied from the downloads folder to the desktop with no problem.
The suggestion that it may be the remote drives is a good one, but how does one resolve this?
