- Sep 17, 2014
OK, excellent information!
It's important to understand that as of now, being able to recover from the Time Machine backups you have been running is "iffy" at best, given the issues the WD drive has. So, it's both critical and important that you get some kind of reliable backup strategy in place.
First of all, Carbon Copy Cloner is way more than just a program that copies information from one location to another. Like SuperDuper!, it also can be used to make a bootable backup/clone of your "system", and in your case, that would be the stuff on your internal drive. You actually have WAY more than enough room on both of your 3 TB drives to 1) partition each drive to create a 250 gig partition, and decreasing the 1.36 TB free to .86 TB free (easily enough space), and 2) have Carbon Copy Cloner make a bootable backup/clone of everything on your internal hard drive to each small 250 gig partition you created. Again, it makes a bootable backup/clone, so you can boot your Mac from that partition. If you ever have a disaster with your internal drive on your Mac, you can boot from that external Carbon Copy Cloner-created partition, use Disk Utility there to Erase, Format, and Partition the internal drive, and then do a complete restore of everything from that external partition to the internal drive. You'd be back in business in no time! And, there are no worries about any of the programs you originally backed up from your internal drive.
You could still use Carbon Copy Cloner to copy the 1.64 GB of stuff from one external drive to the other. The only thing is you just need to let Carbon Copy Cloner what partition to copy (the one with the 1.64 GB of stuff), and where to copy it to (that would be the other partition on the other external drive).
Now, the only possible issue is how and when to run Carbon Copy Cloner. I believe you can schedule it to run when you want, and in your case, that might be necessary. I can do the same with SuperDuper!, but given that I don't use my machine for real "critical" stuff, once a week for my manual backups works just fine.
One thing is for certain, whether you get rid of the WD drive (I suggest you do) or not, is that you still must have at least one backup. And, as I said, you already have one of the best backup programs to do just that!
One other thing: have you been keeping Carbon Copy Cloner updated? Also, what version do you have?
