- Nov 9, 2020
That's real good that you are taking backups, and you have a fall back plan. But regarding SuperDuper! (and in the past, also Carbon Copy Cloner), it's always been the case in the past that an upgrade was not immediately available when a new Mac OS was released. And if you read my post above, #10, about the 3 things to be aware of/considered, waiting to upgrade is the wise thing to do.A good question why upgrade at all - well I am moving from Singapore to Malaysia. In Singapore I know where to get good Apple support (if anything happened in Malaysia I don't) this could mean a delay of upgrading for many months possibly a year or more which starts to bring it's own compatibility problems. I alway had the fall-back position of re-installing Catalina. I also have the option to use CCC as I have it installed on my wife's computer + ChronoSync which I have been evaluating as an alternative to Superduper. To be honest I didn't even think that Superduper would have a compatibility issue I don't remember reading about this before upgrading but then that's careless..
I am paranoid about data back up (off-site, cloud many SSD's) way beyond normal behaviour and as the article you mention above says: "Please keep in mind, however, that your CCC backup does not have to be bootable for you to be able to restore data from it"
It's sad we have to endure OS upgrade issues but really I have endured a lot worse than the Catalina to Big Sur upgrade.
Regarding applications not yet compatible, any such software that needs to operate at the disk/software level would logically fall into that category. Myself, 2 such programs, Onyx, and Tech Tool Pro, are pristine examples. Both of them (along with SuperDuper!) don't have upgrades typically available right away. And I for one like that, as it takes a couple of the releases of the new OS to really get stabilized.
I truly feel the one thing that folks need to consider is whether or not, as I stated above, there is anything "earth shattering" in the new OS that one must have. Myself i have not seen any such thing for the past 6 or 7 versions of the Mac OS, and certainly not for Big Sur.
This year, things were even more complicated. First off, this is the latest I've seen a Mac OS being initially released. Secondly, there needs to be 2 versions of Big Sur, one for Intel-based Macs, and the other for M1-based machines. Third, within a week after the initial non-beta release arrived (V11.0 for M1-based machines, and V11.0.1 for Intel-based Macs), a beta was release for V11.1 of the OS for both. That's not a stable situation, in my book.
Finally, when I finally make the move from Catalina (which is a mature, rock solid OS) to Big Sur, I actually will do a clean, fresh installation (the process I go through is described in post #13 above). I suspect that will be in January, at the earliest, as that is when I am expecting a version of Tech Tool Pro compatible with Big Sur will be available. Of course, that assumes that my other 3 critical applications (Thunderbird, Onyx, and of course SuperDuper!) have compatible versions available. Right now, if Thunderbird and Onyx had compatible versions, I would download and install V11.1 of Big Sur (should arrive real soon) on a partition on one of my external SSDs and test it. But again, I am no real rush. Catalina is just fine, thank you very much.
