Macbook wont turn on after spilled water
I recently, 5 days ago now, spilled water all over my keyboard on my Macbook air and now it won’t turn on. When I connect my charger, it lights up green but I am pretty the keyboard doesn’t work because i’ve tried holding the power button, resetting the SMC by pressing the keys and it won’t respond to anything when I use the keyboard. Does the charger lighting up mean that there’s still hope? Would an external keyboard be able to connect even if the computer is shut down? Thank you
The light on the charger just means that the chargig cuircut board is working.
Unfortunately if you spilled water on the keyboard you most likely damaged the main logic board.
Looks like there is a new Mac in your future.
