- Mar 28, 2024
Hello, I have a problem with my M2 MacBook Pro 13' 2022, Sonoma 14.4.1. When it's charging, it is extremely hot, and I think the fans aren't working. Is there any app you recommend to check the temperature or even activate the fans? I am also considering removing the cover to check if the fans are correctly connected. Any tips or tricks are welcome. Thanks
