Light is on my printer, but there's nobody at home
I have Mac Air 10.15.7 Catalina WiFi
I try to connect Epson printer but is nowhere to be found. I have recently changed provider, the printer hasn't worked since (about 4 weeks).
I cannot find Library to see all printers listed, Clicking on Finder as suggested doesn't bring it up. Would like a little guidance on this please.
Have always loaded different printers without problem, but not this time. This printer is one I have used recently before the change. Advice please
-So, you changed your Internet provider?
-If so, you have a new Wi-Fi router, correct?
-Which model Epson?
OK, thanks.
Sounds like you'll just need to perform the Wi-Fi setup again on the printer, since the network name may have changed. If that doesn't work, then you could try deleting/reinstalling the driver and utility and perform a full setup again.
Epson ET-2650
See if that works.
