Interference from Usb turntable
How do I stop interference form usb turntable? I get a loud ping when I switch turntable off and an intermittent buzz when its on.Ive moved it away as a far as the cable will allow
Is it to do wth recording settings ?
This is usually due to a grounding issue. You light try using a different power strip to plug the turntable into.
