SOLVED Help Connecting New iMac To Old iMac
I just purchased a new iMac and attempting to connect to two older iMacs on the same network. The two older iMacs connect to each other just fine. (2009 and 2011 models)
But when I try to connect the new iMac (2023 model) the log in box shakes indicating the user or password is wrong. I know the password is correct as I use it when I connect to the two older iMacs. The new iMac is connected to the same router and WiFi.
Is it a case the new iMac can't connect to the old iMacs because they're outdated? Or is there some setting or permissions issue I'm not aware of?
Any thoughts appreciated.
I assume you have Sharing File Sharing enabled on all Macs. Do you have File Sharing > Options... > Share files and folders using SMB enabled?
Never assume! Thxs, that was the issue. I just "assumed" the new iMac already had File Sharing on by default. See what I did there?
Well played.
I don't believe macOS has file sharing enabled by default as a security precaution. Glad it's working for you.
Be well,
