Block app (incoming connection) on firewall by applescript
I have a script like below:
Code:
tell application "System Preferences"
    activate
    set current pane to pane "com.apple.preference.security"
end tell
tell application "System Events"
    tell process "System Preferences"
        click menu item "Security & Privacy" of menu "View" of menu bar 1
        if title of button 4 of window 1 is "Click the lock to make changes." then
            click button "Click the lock to make changes." of window 1
        end if
        try
            click button "Turn On Firewall" of tab group 1 of window "Security & Privacy"
        end try
        set visible to false
    end tell
end tell
tell application "System Preferences" to quit
I have two questions as
- when I run it, showed rwarning result like below. Question 1 is what is wrong this code? and How to correct it. I use serria os
error "System Events got an error: Script Editor is not allowed assistive access." number -1719 from menu bar 1 of process "System Preferences"
Question 2 is I wanna add block incoming connection of specific app to firewall. How can I write it on code like above?
You need to open System Preferences> Privacy> Accessibility click the + and add Script Editor.
