SOLVED AirPlay not working on LG TV [SOLVED]
After spending countless hours on the phone with both Apple and LG without any progress, I finally found the solution myself.
Here's what you need to do: access your router's settings and locate the bandwidth options. Once there, ensure that you disable both the low and high options for the 5G bandwidth and confirm that the 2G bandwidth is active. Save these settings before exiting.
I found this after I noticed my Samsung TV, which had no issues with AirPlay, was connected to the 2G network. It was a eureka moment after months of frustration. I hope this helps you out as much as it did for me!
