Hi All
Hope someone can help
I have a Imac G5 With built-in wireless and a G3 Blueberry Imac and I wish to share the same internet connection and possible create a network between both Macs at present the G3 Is used by my 2yr old to go on line to cbbc
At present I have the G5 Internet supplied by a Belkin Adsl Router connected wireless to the G5 and this works perfectly.
My problem is connecting the G3, due to the location the only place I can locate the router between the two Macs in a separate room This making connecting the G3 via an ether net cable impossible. I have purchased a USB Wireless Lan Adapter and I have try to connect via this but with little luck
Is there ant one with the knowledge as to connect the two Macs before my son falls out with me
Regards
Paul
Regards
Paul
