Wireless Help
I have an IMac G3 that is running OS X, which needs to be hooked up to the Internet. No direct line is available, so I'm going to network it with the other computers in the office. I wanted to know what networking card is best i.e. Airport Extreme Card, Wireless PCI Card. It would be a big help for some feedback
what kind of imac do you have ?
hopefully a slot loader because if you dont you can forget about airport they dont have internal support for airport
also nix a pc card imacs dont have room for that they dont even have the slots
edit :
to make it more simple
if your imac has a cd tray you need to pull out
you can use an airport card these are the first imacs and they have no airport connection or the room for one
for these models all the expansion you have are the usb plugs
if you can push the cdrom in a slot then you can use a airport card
..unless its the 350 mhz one then you cant
There are a number of Wireless Network USB "cards" that probably can help getting a Wireless connection if he computer can't get one installed internally. Other people on here would have to tell which ones are compatible with macs though, as I have no idea.
nor do i
the best advice i can give you is
is it a slot loading imac G3 ? go for airport its just a wifi standard anyway
if not your only option is a usb wifi card
