- Nov 28, 2015
I'm using Winebottler Version 1.7.53 (http://winebottler.kronenberg.org/downloads) to convert several Windows applications to run on OSX. It seems to be a bit erratic. It takes several tries before it does the conversion. My main issue is that it only converts one particular application in a bundle of six shareware applications.
This is the shareware software bundle that I'm trying to convert:
http://machinehead-bicycle-software.software.informer.com/download/
The bundle actually does work with Virtual PC 6.1 and Windows 2000. But when I convert the software to run on OSX, only the spoke length calculator application is converted and not the other 5 applications. It creates an application titled:
"Bike Software.app/". It opens to an application called "Wheel Calc" for calculating spoke lengths for bicycle wheels.
I'm using an early 2011 - 17" MacBook Pro with OS 10.6.8 (Snow Leopard). I have just done fresh reload of all my software onto a hard drive.
If anyone has the time or inclination to attempt this conversion I'd appreciate it. I'd like to know whether it's my error or just not possible to convert the application with this version of Winebottler.
