Window size problem
When i load programs
the size of game screen is smaller than the window
I have a apple macbook pro retina 15-inch Mid 2014 Os X 10.9.4
it's because they are not designed for the retina screen.
You can go into Monitors and change the setting while using that App, or contact the App makers and tell them to fix it.
I've contacted the creator
i do not have a option to change monitor settings for the app
No, it's not a per App setting, you will need to change it while you play that game, then change it back when you're done.
