- Sep 25, 2015
So my house wifi went down, and while we're waiting for it to be repaired, we're using our neighbor's wifi. I'm slightly astonished, because my 2011 MPB picks it up with full bars, while my new 2020 M1 iMac, sitting right next to it, can BARELY connect, with just about one bar, and frequently loses connection.
As far as I can tell, the reason is that my MBP has decided to connect on channel 1 of 2.4 GHz, and the iMac has decided to connect on channel 40 of 5 GHz.
How does one change the wifi channel that the Mac uses? As noted, I don't have control of the router.
Sigh. After a day, the iMac has decided (all by itself) to switch to channel 1 of 2.4 GHz, and the reception on it is still crap. The RSSI is the same on both machines, so one machine is evidently a lot less sensitive. How do I improve the wifi reception on a new iMac???
