WiFi or Ethernet do not work! (need to renew DHCP lease) works 10 seconds
I Have a Macbook and the Wi-Fi or connected Ethernet will not work. I renew DHCP lease and the internet works for 10 seconds than I have to renew it again. I have 2 more Macs and they work fine. I have two routers (cable and DSL) and this computer has the same problem with both. Is there a way to solve this?
I have notice that a lot of people have had this problem has anyone resolved this issue.
MacBook, Mac OS X (10.6.8), 2.2 GHz Intel Core 2 Duo 1 GB
So far this is what I have tryed:
Macintosh> Library> Preferences> SystemConfiguration (deleting all documents in this last folder).
-reseting router
-Macbook Software update
-Flush DNS cache using Terminal (dscacheutil -flushcache)
-holding Command+Option+P+R during restart until hearing another chime
-airport on/off
-removed airport and added again from Network Preferences
-Network>Advanced (deleted Preferred Networks and also from Keychains)
A couple if things,
1) How long has this issue been going on.
2) Have you downloaded any video codecs recently.
3) Also try this make a new user account and see if the issue persists. If it does then I would run a hardware test as follows.
Boot off your Install Disk while holding down the *d key*, (not c key), then run the extended Apple Hardware Test, and see if the Airport card passes.
EDIT:
Have you logged on to a public WiFi or friends system recently?
