- Nov 9, 2020
Saw this earlier today on the site tidbits.com:
Definitely worth reading and heeding the suggestion to avoid it for now. And the part about cloning software, and specifically SuperDuper!, definitely hits home with me. And notice this statement from the article about CCC:
"However, we can’t recommend upgrading to an operating system that requires a beta release to make bootable duplicates"
I am going to wait to test Big Sur, most likely shortly after V11.1.x or V11.2.x appears. And again that will be for testing only. Will still be using Catalina as my primary, day to day OS. I am anticipating not moving to Big Sur until January, as that is when I expect Tech Tool Pro will have a version that is compatible with Big Sur. Of course, that assumes that my other 4 critical applications will already be compatible with updates.
