- Mar 24, 2013
I have a problem with drivers and would appreciate help.
I am trying to run a Blackmagic ATEM TV Studio from my MacBookPro which connects vis Ethernet and USB. I've got an Ethernet/USB adapter which was working fine and then I decided (as it was good housekeeping) to make sure the drivers were up to date. When I loaded from the supplied disk the Ethernet connection stopped. When I check the hardware profile it can see the ethernet adapter and has the correct name but when I check networking to alter the IP etc it shows as Ethernet Not Connected.
When I connect to my iMac without the drivers everything is fine. I'm new to Mac so would appreciate some assistance. I can't see the drivers anywhere and I've opened up all the hidden files, checked the modified dates etc and tried a search but still can't see them. I think I need to delete them but how do I do this if I can't see them.
When I used a PC I would simply use System Restore and revert to a point before I installed the drivers - is there a similar mechanism for Mac? Thanks.
