- Apr 9, 2021
I have a very old Mac from 2009 which, prior to a format, was upgraded to Lion. After formatting, I unfortunately found that I had lost the installation disk for Lion and that I only own the one for Tiger, which I normally use. To my detriment, I discovered that there is no "via system" upgrade from Tiger to Lion, and it necessarily requires the disk. I called the Apple to buy it but they told me “it is no longer on the market”.
I was wondering if it is possible to do some installation through alternative ways thanks to a USB stick: on the internet I don't find anything or almost nothing. Also I was wondering if it is possible to install later versions of Lion: I know my PC is too old and it could not, but I would like to force the installation if possible.
