Two airport extreme
I would appreciate if anybody could tell me if two airport extreme conected with the same server can work with different passwords. Thanks
Sure, you probably want to give them different names too, that way you can choose the right one to log into.
Thanks you for the reply. Do I connect them to the moden through a Y connector or one after another (in line)
Y connector
You don't want to end up with a loop. If your modem does't have 2 ethernet ports and if they are new enough, you can chain them wirelessly. Or get a Ethernet Switch, ensure its fast enough the cheap ones can slow down the network.
