So, I am updating my system and trying to get with the times and use dropbox for most of my files. I thought putting my fonts would be easy and followed this tutorial:
- Go to your home folder in Finder.
- Copy your Library/Fonts folder inside your home folder into your Dropbox folder. Be sure it all copied before moving on.
- Open Terminal in /Applications/Utilities. Don’t worry. This won’t be hard.
- Type sudo rm -rf ~/Library/Fonts and press enter. It will ask you for a password, type the password you use to login to your Mac.
- Type ln -s ~/Dropbox/Fonts ~/Library/Fonts and you’re done!
