- Dec 22, 2010
Hi there, I'm using a MacBook Pro - on 10.6.5
I was using peerguardian earlier while connected to my home Wi-Fi, I clicked disable filters but it gave an error message.
It seems after that I can't even find my wireless network now, even when i try and put the network details in manually, it says 'timed out.' I've deleted peer guardian and restarted several times. I don't really know what could have changed.
It's definitely nothing to do with my Wi-Fi network as there are other devices connected to it no problem, while my macbook can't even find it.
Any help would be much appreciated.
Thanks, Adam
Thanks, Adam
