Hi people,
Cleaning out and changing the harddrive on this Mid 2011 iMac 21.5"
Having two different problems trying to put this piece back in place.
First the T6 screw I took out won't go back in. IDK if I stripped it or if there was another piece in the hole, but now only a T8 will screw in. Problem is the T8 won't go through the hole on piece to clamp it down.
Second is the third connector at the bottom won't stay snapped in, detaches easily.
