Okay. I have two errors and i'm not sure what the hell to think about either of them. Okay. So... First off: The... hotkeys on my keyboard (The little buttons with the graphics on them, such as sound, brightness, etc), I have them assigned so that their designation (Brightness, etc.) Will only activate if I hold the Fn key. Simple enough. Either way, whether it's on or off, when i hit those keys, instead of doing their function, will open up a System Preferences pane (Ex. Mute button brings up the Sound menu). As if that wasn't annoying enough, It's deciding to randomly hide windows - By that, I mean the kind of hide you access from the toolbar, which is accompanied by Show All, as opposed to just minimizing it
I've had this mac since 2008, never had any problems like this before.
