I have the same problem as in this thread :
https://www.mac-help.com/forums/showthread.php?p=5788
But unfortunately after running the /sbin/fsck -fy code, it tells me that macintosh hd could not be repaired.
Here is the script it shows after entering the code:
**/dev/rdisk0s2
**Root file system
**Checking HFS Plus Volume.
**Checking Extents Overflow File.
**Checking Catalog File.
disk0s2: 0xe0030005 (UNDEFINED).
Invalid node structure
(4, 10608)
**Rebuilding Catalog B-tree.
disk0s2: 0xe0030003 (UNDEFINED).
**The volume Macintosh HD could not be repaired.
localhost:/root#
please help me! Thank you do much for any advice you are able to give.
Steph
**/dev/rdisk0s2
**Root file system
(4, 10608)
localhost:/root#
Steph
