- Oct 23, 2008
I've been noticing that the start-up on my 1.8 GHz iMac G5 (running PPC chip, 512 MB, Tiger OS X - 10.4.11) has been running much slower than usual. Now when I turn on the machine I'm staring at the gray background watching the little turn-table icon spin beneath the Apple logo for 15 seconds or more. Once the machine is up and running, everything runs at its normal fast speed.
I've never installed or used anti-virus software on this machine before, so thought that maybe I've been a little reckless there. So, today I downloaded, updated and ran ClamXav anti-virus. It found ten infected files, all in the Library/Caches folder. So, I deleted those files and rebooted.
However, when I restarted the computer it was still starting up slow. So, I thought I'd better clear out the cache and get the system organized. So, I downloaded and ran Leopard Cache Cleaner (latest version does Tiger as well), and completely cleaned out the cache files, and organized the system files (apparently). However, the computer is running slower than ever.
Last week I had another problem that may be related. My Mac mail was not receiving mails, even though I could send mail from Mac Mail. I could receive the e-mails from my ISP's website via Safari, but not on Mac Mail. After my ISP assured me that my settings were fine, I clicked on my System Network Preferences, and a box popped up saying that my Preferences were being changed by another application. I could not check or change any network preferences. So, I checked on mac-help.com and found that a Mac security update was apparently causing this issue. I followed the instructions and set up my security preferences so that a password would be needed for any changes to preferences, and now the pop-up is gone, and I can change the network preferences, and NOW Mac Mail is receiving e-mails without any problems. Lastly, I do not use any file sharing applications, and my Mac Firewall settings are at their highest, so basically nothing can get it.
However, after all of the above my system start-up is still running slow, in fact the start-up is slower than ever. Again, once the system is past start-up, everything is running fast as usual.
One thing that does have me perplexed is that when I click on Macintosh HD on the desktop, and then click Network there is a folder called Library at the top that I do not recall seeing before. The folder has one file, showing 1kb, called library, with type listed as alias. When I click on the folder a pop up appears saying "The alias "Libary" could not be opened, becuase the original item can not be found", along with three buttons, Delete Alias, Fix Alias and OK. However, if I try to delete the folder by clicking delete or by dragging it to the garbage can another box pops up saying that "the operation cannot be completed because you do not have sufficent privileges for Library". What is this folder, do I need it, can I delete it, and how?
Beneath the folder Library there is a icon called Servers. When I click on this, I see a listing of what's on the Macintosh HD folder on the desktop. Is this a case of major file duplication or just another way of showing the same data?
My feeling is that this strange Library file is slowing down my system start-up, but I really have no idea.
Based on all of the above, can anyone help me get my start-up running? And, if any of the above info looks like a virus or malware or trojan attack, please let me know.
I'll keep you all posted of my success with this issue. Cheers.
