Have you ever had need to look for files that have been saved and resaved numerous times? Like when you want to access a previous version of the file that you have saved and resaved numerous times? That’’s where TM shines. Or how about if you accidentally deleted a bunch of files, or even a whole drive? But if your search requirements are modest, the other search apps should suffice.Time Machine is the built-in backup feature of your Mac. It is not a Finder app
The feature I was talking about is automatic saving of searches. Any comment on that?
Easy. Open the folder that contained the deleted file. Launch the Time Machine app. When it shows the time line on the right edge of the screen, you can scroll back one step at a time or to the point when you deleted the file, if you can remember. Then trigger the restore by selecting that file (or folder) and click on Restore. When it’s done, your missing file should show up in that folder.I recently deleted a file.
You cannot make a search in TM
Is there no recovery app ?
My information source for many applications is MacUpdate.BTW: I do not remember the folder that contained the file. but remember only the file name
Alternative to TM is a recover app like WonderShare RecoverIt. app, did you try that ? expensive. Is there a cheaper recover app ?
