I'm running both 10.3.9 and 10.4.3 on the same computer on different drives.
I can run 10.3 ok
when I switch to 10.4 the usb light stays red, the diagnostic has no information within the connection area (ie VCI, Type & Encapsulation)
I have tried various methods of uninstalling and reinstalling - including the old CD and speedtouch update, and a straight update from their website.
essentially i'm not getting a "new port detected" in the network configuration.
Can you answer the following:
Is this a 10.4.3 problem or my ISPs problem?
(or just my problem) and is there a fix or test i can perform?
thanks for any help you can supply
Jon
I can run 10.3 ok
Jon
