SOLVED Sound in Safari
I have posted about this before, I cannot get Safari to produce sound, eg if I have a Utube video with sound I hear nothing. With Chrome or Firefox, it's fine. Both main speakers & ear phones. It started when I used Loopback audio,. Can't uninstall Safari.
-Yes, I remember...you were dealing with headphones I believe?
-Do you mean the Loopback from Rogue Amoeba? If so, try turning off all the devices in Loopback to disable them and use the Mac's audio normally. Also, is there something setup in Loopback with Safari involved?
Yes, the problem never really went away. In "sound" I have Headphones, Loopback Audio, Loopback Audio 2 & Screenflick Loopback. I cannot delete any of them. I have deleted Screenflick. I have output set to Headphones.
OK...
So it is Screenflick Loopback then. There may be a way to disable it, or uninstall if you aren't using it. It sounds like it is "capturing" and re-routing the sound from Safari.
I have deleted Screenflick, but Loopback still in Sound Preferences. Can't delete it. When I search for it using Finder...nothing is found.
Did you open Screenflick Loopback, click on Audio Extension, then click Uninstall before uninstalling the Screenflick Loopback application? Those steps are outling in the link above.
well, I have reinstalled Screenflick 2.7.50 but cannot see anything about audio. Strange.
Hmmm...
So, this isn't accurate?
Cannot see that anywhere. Curious that there is no mention of the word Sound in any of the menus . Looked in Library/sound/Plug-in and deleted that. Restarted and looked in sound preferences and saw there were still 2 Loopback audios in there. Tested sound and it neaarly blew me out of my seat. So working again. Thanks Cory
