I did as the thread suggested. Hit the start button, then pressed and held OPT+COM+P+R, through the initial start up screen, then a black screen, then a second start up screen until I had the Apple symbol and progress bar. When it started I had a utility screen which offered to RESTORE TO ORIGINAL OS CONFIGURATION or RE-INSTALL OS FROM A DISC or UTILITY DISK. IT then asked me to restart. I did this three times with the same results. Each time I set the volume level and then shutdown and restarted, but the volume control still defaulted to zero. Any other ideas or did I do it wrong?
