- Jul 16, 2008
My specs are:
Mac OS X (Tiger) 10.4.11
1.5 Ghz Power PC G4
512 MB DDR SDRAM
I have not modified the computer hardware, system or OS in any way since purchase (approx 2 1/2 years ago)
My problem:
About 4 months ago my mac started to go through periods of lagging / freezing; it processes commands extremely slowly (i.e it will take about a 40 seconds to register a click on an icon) and the computer itself makes a rhythmic (small pulses) 'crunching' noise; the same type of noise it makes when it starts up - I have presumed this is the computer accessing the HD, but i don't know. Characteristically this would happen when doing one of the following things:
1. running a large amount of programs at one time
2. when installing something it would always happen when the installation program was looking for a destination to install the program on (i.e when you see the little picture of your hard-drive)
3. sometimes it would just happen randomly, seemingly without any outside input.
Lately this problem has been more frequent, however it seems to be related to my other problem which is the failure of my MS Word 2004 (mac office version 11.4.0). when trying to open a saved document, save a new document, or make any change in font style etc the application will freeze, the computer will display the symptoms that I described above and will stop when I (eventually) manage to force quit. I have tried updating to office version 11.5.0 however when I start the installer it returns the following message: "The installer could not locate the correct version of the software required to install this update". I discovered somewhere else that 11.5.0 could be installed on any version of word, even so I tried installing 11.4.1 and I got the same message.
I have tried the following in order to fix the problem:
1. I have repaired file permissions using disk utility
2. I have put the computer into 'single user mode' (or something like that - i.e I rebooted and it came up with a black 'command' screen.), and then performed a disk repair using 'fsck -f'. when I ran this command the following output was returned:
**/dev/rdisk0s3
**Root File System
**Checking HFS Plus Volume
**Checking Events Overflow File
**Checking Catalog File
disk0s3: I/O error
Invalid node structure
(4, 12451)
**Volume Check Failed
Any ideas or suggestions would be greatly appreciated
Thanks,
Angus
My specs are:
1.5 Ghz Power PC G4
512 MB DDR SDRAM
My problem:
**/dev/rdisk0s3
**Root File System
disk0s3: I/O error
(4, 12451)
Thanks,
Angus
