Hi..need some help as I am new to Mac's.
My wifes Mac Pro suddenly would not boot. I tried running the tiger os disk to access repair utilities but nothing happens, the screen is on but has a flashing folder with a ? on it. I figured that it was the hard drive so removed that and connected it to my win7 pc and ran MacDrive 8 to access it. I managed to retrieve important data from it but still could no repair it.
With the drive still connected to my pc, I booted with acronis to repair the drive. I found that the drive had a 2meg fat32 and 465meg efi partitions. I could not repair them so deleted the partitions and installed a single partition of 465 gigs formatted with Fat32 thinking that the Tiger os would install if it at least found the drive. The drive seems ok as it is as I can see it in win7 and is ready for use. I put it back into the Mac but the tiger os still wont see it.
I am not sure what the problem is here but can anyone advise on how I can prepare the drive so that the Tiger os will see it and install the os?.
