[SOLVED] Display larger than screen
Hello everyone,
I have a MacBook Pro with OS X version 10.4.11
My display has somehow become 'bigger' than the screen. So if I move to any side of the display it continues moving outside the screen size about 2cm. What is displayed on the screen is also a tiny bit hazzy.
I've had some non-mac visitors staying with me and I think it must have resulted from something they've accidentally done. They swear nothing weird happened or that they've changed the settings.
Before I start looking at the display size (which I know nothing about) I thought I'd ask here. It's currently set on 1440 x 900 but I have no idea if that was what it was on before...
Any suggestions?
Thanks for your help!
