- Oct 26, 2016
My 2011 21.5inch iMac [High Sierra 10.13.6] has two slots on the right hand edge of the display case. A CD drive is above the SD card one.
I have put a SD card into the CD slot & cannot retrieve it. This means that I cannot put a disk in.
All the other workings of the iMac are unaffected. I can use thumb drives using other USB slots.
I know that in normal disassembly the front of the screen is vacuumed off, leaving the other parts sitting in the back shell. In that state it would be simple to recover the SD card.
Has anyone any other ideas for removing the errant SD card?
