- Apr 26, 2007
Hello everybody!
I got some problems saving an document from Quark Xpress 6.52 to an mounted volume.
I tryed the following:
This did not work. When I use the following code-line
it works fine, because there is no alias like in the volumes-folder.
So, what do I have to do to save my file on the mounted volume "kundenordner". The full path I need to save in is: "VBU01 HD:Volumes:Kundenordner:0-9". The mounted volume is called "Kundenordner" with an subfolder called "0-9" and in this subfolder of the mounted volume "Kundenordner" I want to save the file.
Thanks for your help!
Greetings
Christian
Code:
tell application "QuarkXpress Passport"
activate
make new document at beginning
save document 1 in file "VBU01 HD:Volumes:Kundenordner:0-9:try2.qxp" as alias
end tell
Code:
save document 1 in file "VBU01 HD:quark_temp:try2.qxp" as alias
Greetings
Christian
