MBP 13" Retina early 2015
Using a Portable HDD for compactness means no external power supply and so power is drained from the battery, thus more recharges, less time etc.
To overcome this I use a desktop HDD but still use a Samsung T1 SSD also.
I am concerned that if I use a Y USB 3 cable (using one leg to supply power only) there may be slight differences in voltage at the Mac port or that the Mac port will still supply half the power.
Can anybody please suggest the safest solution.
