running application indicator
I used to have a little dot next to the applications that are running. I have updated to Mountain Lion, and only now noticed this problem. Any suggestions?
-I assume you mean in the Dock?
-You don't see this in Mountain Lion?
Indeed, I do mean a little dot for running applications in the dock. No, I'm not seeing it in Mountain Lion - anyone else?
It's there on my MBP running 10.8.1.
-What type of Mac/display are you running? (Could be getting cut off at the bottom as it is lower than it was previously)
-Try moving the Dock to the left or right side and see if it's there.
Wow. I moved the dock around and then put it back and voila, there are the dots. Thanks. I mean really, thanks!
