Replace Power Switch on a 15" MacBook Pro mid 2014 with 2.5 GHz with Intel chip
It can now take a minute or longer to turn on the computer with the power switch. Can the switch be replaced without replacing the motherboard? As a temporary work-around, I've been letting the computer SLEEP instead of turning it off like I normally do.
Do you have a recommended service center or individual within driving distance of Thousand Oaks, CA that can help me?
The power switch is actually part of the entire upper/top case assembly with the keyboard. That would be the part that needs replaced.
Unfortunately, the MacBook Pro (Retina, 15-inch, Mid 2014) is now Vintage, so Apple and most Apple Authorized Service Providers won't service it. You may be able to find parts or a repair shop that can source parts and repair it, but I am not familiar with any in the Thousand Oaks area.
Hope that helps and good luck!
