Remote installation OS X help, network doesnt show
I am currently trying to remote install snow leopard from my imac onto my macbook pro using remote installation technique. this is due to my macbook dvd reader is screwed.
the guide states that when i start my laptop and hold down the option key a drop down menu of airport/networks should show, however this does not apear, only the hard drive icons appear.
how do i get this network list to appear? in order to remote install?
