Hi all,
there are times when you really need help...
To best help you I may suggest that a member of mac-help.com accesses your Mac via Remote Access.
(Currently the only person doing this is Ric !)
Ther are numerous ways that we can do this, generally we use Apple's Remote Desktop software (ARD).
This allows us to 'take control' of your Desktop...you watch everything that's happening and can terminate the connection at anytime.
This is a very quick and efficient way of us helping people, and you get to watch and learn at the same time.
First you need to allow Access through your Firewall, if you have one.
If you are running Mac OS X Tiger then follow the screenshots below. If you are running an older version of OS X let us know and we will talk you through the correct config.
Open Sharing Preferences:
Then you will see this screen:
Tick the box next to Apple Remote Desktop:
Now click on the "Access Privileges Button"
Now you should see this screen:
Please click the checkbox that says "VNC Viewers may..." and then type in the password that we have decided to use !
Then we need to configure your Modem to allow all traffic for Remote Access to get directed to your Mac...this is called port forwarding. If you are using a USB modem, you can ignore this bit you are good to go !
Now your Mac is ready, we need to set up "Port Forwarding"
Don't worry it's not to hard to do...
By using VNC we only need to forward one port...5900.
So first you need to login to the admin software of your modem, for example on a Netgear DG834 Modem you would type
192.168.0.1
into your web browser this would then give you a screen like this:
more to follow...
192.168.0.1
more to follow...
