- Feb 18, 2020
About a week ago i started hearing a rattle noise from my Macbook Pro 2018, which seems to come from the left fan. You can hear it making the noise as it slowly speeds up the fan. It will keep making the noise for about a minute, where it then fades out and then seemingly works fine until the notebook is turned off and on again. The sound it emits is similar to that of lifting the notebook too fast while fans are spinning.
Any clue on why the fan only makes the noise in the first minute of it being turned on? Is it an indication of the fan being worn out and perhaps needs replacement soon, or could it be a minor thing that I could try to fix myself? Would love to hear your thoughts.
