Problem with Terminal [solved]
Hi, i tried something (not so smart) yesterday: i changed the privileges for the /usr folder and immediatly after the my Terminal refused to work with the following message: login(307,0x7fff759b6960) malloc: *** error for object 0x7fb5a9d00000: pointer being freed was not allocated *** set a breakpoint in malloc_error_break to debug After is saw this i changed the privileges back but my Terminal still won't work. So I have no idea how to fix this and hope that you can help me. Edit: using the "repair your disk permissions" from disk utility did the trick!
