Problem with Parallels
Whenever i boot up in coherence the colors are all warped. this started happening after i torrented Diablo 2 (Which i own BTW). any fixes people have found?? i use coherence alot and this really prevents me from fully utilizing it correctly
Unfortunately, we don't support Windows.
But, it looks to me from the screenshots, that the display settings are corrupted or set too low in Windows/Parallels. It looks lit 8-bit color to me, instead of 16 or 32-bit color.
-Check the Display settings in Control Panels
-Make sure the Parallels Tools are installed/up-to-date
-Does it do the same when not in Coherence mode?
If those suggestions don't correct the issue, I would post this on the Parallels Forums.
